Peterkopp
Grünschnabel  (24 Punkte)  ·   männlich  ·   Niederlande  ·   Nachricht senden
 http://www.daxmagic-webshop.nl
How to copy products from one shop to one other ?
Hi again
I am a Shop11 user, and have used all versions before for years
I have a multi language system as well and the same shop in 5 different languages
Sometimes the synchronization function fails and forgets to copy everything to all 5
Then I have to copy products by hand, but this is not possible, so I have to type it all again and again.
Anybody has a trick to do this ?
Greetings
Peter
uli99
Forum-Sponsor  (454 Punkte)  ·   männlich  ·   Deutschland  ·   Nachricht senden
Maybe You should use the plugin for different languages? The Google Translator Plugin...
MfG Uli
Werkzeug: Siquando Shop 9/10/11 - Template Vertika 9/10/11 - WAWI: Abamsoft Salida 2020 - Siquando Pro Shop 4/5 nur zum Testen
Peterkopp
I have the plug in for more languages, but you get the same shop in different languages which are separated shops on its own
But sometimes its fails to copy things the the other shops
Google translater works but sometimes you get strange text, to English, French and German is ok but other languages I see strange things
Peter
76 Aufrufe | 3 Beiträge
