Peterkopp
Grünschnabel  (17 Punkte)  ·   männlich  ·   Niederlande  ·   Nachricht senden
 http://www.daxmagic-webshop.nl
Google users can still buy invisible products
Hi
I have this problem for years now
I am a Shop11 user and the same problem is still the same as with all the older Shoptodate versions
When people find a product using Google which is not in my shop any more because it is sold out at his moment and is not visible in my shop, they can still buy it.
When something is not visible in my webshop is should not be possible to buy it anyway.
There should be a link between being visibel or not and shop function
It would be a big improvement
uli99
Forum-Sponsor  (452 Punkte)  ·   männlich  ·   Deutschland  ·   Nachricht senden
Only deactivate the "Buy Button" by set it visible in a past time... So it is then not possible to order... 😉 🙂
MfG Uli
Werkzeug: Siquando Shop 9/10/11 - Template Vertika 9/10/11 - WAWI: Abamsoft Salida 2020 - Siquando Pro Shop 4/5 nur zum Testen
Peterkopp
Thank you
This is a great trick 🙂
I asked the helpdesk before but they had a complicated system which was a lot of work every time
Greetings
Peter
55 Aufrufe | 3 Beiträge
