Regio
 http://www.regio-handel.de
Immwr wenn ich bei dem neuen Shop 5 Prodkte anlegen möchte bricht alles zusammen.
Ich erhelte dann die Fehlermeldung:
System.NullReferenceException: Object reference not set to an instance of an object.
  at SiquandoNG.UI.ListViewEditableProducts.AddProduct()
  at SiquandoNG.UI.ListViewEditableProducts.buttonAdd_Click(Object sender, RoutedEventArgs e)
  at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
  at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
  at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
  at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e)
  at System.Windows.Controls.Primitives.ButtonBase.OnClick()
  at System.Windows.Controls.Button.OnClick()
  at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
  at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e)
  at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
  at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
  at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
  at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
  at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
  at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
  at System.Windows.Input.InputManager.ProcessStagingArea()
  at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
  at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
  at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
  at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
Kann mir jemand einen Tipp geben?
Vielen Dank
BG Fred
  at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
  at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
  at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
  at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
  at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Forum-Sponsor  (1085 Punkte)  ·   männlich  ·   Schweiz  ·   Nachricht senden
Hallo
irgendwie Komisch ich habe in der Zwischenzeit jetzt schon einige Produkte im proShop5 angelegt und noch kein einziges Problem feststellen können. Daher Frage wie ist Dein genaues Vorgehen
  • legst Du erst eine Produkteseite an?
  • oder versuchst Du zuerst das Produkt einzustellen?
  • machst Du einen Import über die csv?
Könnte es allenfalls auch sein das Du die Grundinstallation proShop5 nicht auf den Server hochgeladen hast, oder aber nicht ganz Vollständig? Komisch ist auch das Deine erste Fehlermeldung " at SiquandoNG.UI.ListViewEditableProducts.AddProduct()" mit NG.UI beginnt errinert mich an die Lizenzdatei bei Siquando.
Gruss René
656 Aufrufe | 2 Beiträge
